Choosing and Siting a Turbine
Choosing the right turbine for your needs can be a daunting task.  Not only are there different makes to consider, each manufacturer may have a range of sizes!  How do you decide which one is best for you?
The first step we would always suggest is to analyse you present energy consumption.  Dig out your last years worth of electricity bills (more if you have them) and work out your average annual electricity consumption.  Your electricity bill will show kWh or units of electricity, often at different charging rates, especially if you have an off peak tariff, storage heaters, "White Meter", "Economy 7", etc.
A turbine is ideally suited to displace the expensive rate electricity, that is the electricity used for lighting, sockets, cooking etc.  Once you have worked this out, you need to decide at some point in the process if you need a turbine that will meet all your annual demand, just part of it, or an excess that can be sold to the grid.
Next, you need to determine what the windspeed is at your site.  To do this properly requires erecting a mast with an anemometer, ideally for a year or more.  This can be expensive, and a delay you perhaps don't want before you get your turbine up and running!  An alternative is to estimate the windspeed at your site using the NOABL database.  This gives estimated windspeed at 10, 25 and 45m above ground level for each of the 1 km squares on the UK Ordnance Survey mapping.  Whilst only an estimate, this is a useful tool to help assess your site.  We recommend you access the database through the BWEA Website NOABL page and read up the notes on assessing wind speed before trying to put in your co-ordinates!
Once you have an estimated wind speed, and idea of how much of an impact you want to make on your electricity bill, you can see how the different turbine makes and models will produce in your estimated windspeed.  One easy way to do this is to use Eoltecs power estimating spreadsheet.  This is Microsoft Excel based and you can download this for their 6 kW Scirocco, or if you need a larger turbine for a commercial or community project, their 25 kW Windrunner
We also recommend that you look at actual production which other owners are getting, as there can be inaccuracies in using the NOABL model, especially if you have a lot of trees or other obstructions around your proposed site.  One place to look for real life data from other turbine owners is on the renew-reuse-recycle.com website, where the turbine owners have been logging their monthly production data for a range of different turbines in a variety of windspeeds.  A graph of relative production figures is shown here.
Now you should have an idea how big a turbine you need, and how much energy it is likely to produce!  Don't worry that the power rating might seem low.  Some people have said to us that a 2.5 kW turbine would never do them, as their kettle alone is 3 kW!  But bear in mind that the turbine will run for 24 hours a day, and the kettle only needs a few minutes to boil!  At times of higher demand, the grid will make up the shortfall!
As a rough rule of thumb, a 2.5 kW turbine in a good windspeed site will capture enough energy to meet the annual electricity demand of a typical house, whilst a 6 kW turbine will generate enough energy to do the heating as well.  However, if your windspeed is not so good, you might need a 6 kW turbine just to meet the annual demand for the non heating electricity.
You can also estimate the amount of energy produced by multiplying the turbine rating (in kW) by 24 hours in a day, 365 days in a year, and the Capacity Factor.  Capacity factor is a measure of how productive the wind turbine will be on your site.  A very good site (like Orkney!) might have a capacity factor of 50%, whilst a poor site only 10%.  If the Capacity Factor was 30 for a 5 kW turbine, the annual energy yield would be
5 x 0.3 x 24 hours x 365 days = 13,140kWh per year.
This is also a good time to assess your overall energy efficiency.  Visit the Energy Savings Trust's website for hints and tips on reducing your energy demand and making your home or business more energy efficient.
The turbines that we supply vary in size ranging from 2.5kW to provide power for an average household, to 250kW turbine for larger community scale projects, schools or business premises.
Choosing a turbine very much depends on what you want the turbine to provide power for and on your budget, however there may be a grant from a funding stream to assist you in financing your wind turbine.
Funding and Grants.
It’s important to remember that costs always vary depending on location and the size and type of system. Turbines can have a life of up to 20 years but will require regular servicing and maintenance checks to ensure they continue to work efficiently.
Financial Examples.
Siting and planning considerations
The optimum site for a wind turbine is a smooth-top hill with a flat, clear exposure, free from excessive turbulence and obstructions such as trees, houses or other buildings. However, other areas may have a sufficient wind resource to make an installation worthwhile.
Wind speed increases with height so it is best to have the turbine high on a mast or tower.
Planning issues such as visual impact, noise and conservation issues also have to be considered. System installation normally requires permission from the local authority. Normally, we would recommend that you consider siting your turbine at least 10 rotor diameters (blade tip to blade tip) away from the nearest third part property.  Less than this may be problematic at the planning stage.  More than 10 or even 15 rotor diameters is much more likely to be viewed favourably.  For a 6 kW Eoltec Scirocco turbine, this equates to 56m, although 75m would be preferable.
We would advise that you seek the advice on planning permission from your local authority at an early stage.
Grid connected Wind turbines
During periods of windy weather you might produce more power than you are using. Power generated by a grid-tie turbine can be exported into the grid when it is not required; therefore the power is never wasted.  It also means you don't need any changeover switches to switch back to the grid in times of light winds.  The changeover happens seamlessly and automatically.
No battery storage is required. A special inverter and controller converts raw power output by the wind turbine, DC electricity, to AC at a quality and standard that is acceptable to the national grid and is fed directly into the house or business fuse board.
Any unused or excess electricity that is exported to the national grid can be sold to the local electricity companies generating an income. A connection agreement is required with the electricity company.
On the other hand if you are using more than the turbine is producing at any particular instant, or if there is not enough wind, the electricity flows from the National Grid connection and is drawn from the grid as normal, switching back again automatically when the wind speed resumes.
Grid connect systems are cheaper and require less space and a bit less maintenance than battery systems.  They are also easier to sell the Renewable Obligation Certificates from.
Stand alone / Off grid turbines
Wind turbines are particularly suitable for remote locations that aren’t connected to the national grid (off-grid) where conventional methods of energy supply are expensive or impractical.
Designed to operate where there is no mains supply, an off grid wind turbine together with a battery / inverter system, to convert DC electricity to AC (alternating current -mains electricity),  provides a renewable energy system where it is possible to have a continuous reliable source of power at 240 volts AC.
The size of the battery bank determines the time appliances can be run if there is no wind. The size of the inverter installed determines the number of appliances that can be run at the same time from the stored electricity.
A controller is also required to ensure the batteries are not over or under-charged and can divert power to provide heating through storage heaters or hot water radiators.
It is common to combine this system with a diesel generator for use during periods of low wind speeds. A combined wind and diesel system gives greater efficiency and flexibility than a diesel-only system. It allows the generator to be used at optimum load for short periods of time to charge batteries when there is little wind, rather than by constant use at varying loads.
An off grid system is not normally recommended when the grid is available.  The grid provides an excellent back up supply for times of no wind, and is like a huge battery!  You can sell surplus electricity into it, and buy it back when you are short!  And unlike most batteries, the grid doesn't need replacing after 10 years!
Direct Heating turbines
One of the largest costs to households or buildings is heating. At night or anytime that not all the power from a turbine is needed, the excess can be "charging up" storage radiators or heating up a water tank to supply a conventional central heating system.
A direct heating system is simpler than a grid connected or an off grid turbine, but a separate electric heating system is also required, which may make the entire project more expensive than a grid connect.  There may also be difficulties in claiming Renewable Obligation Certificates for a direct heating system due to the fact that the voltages and frequencies used are non standard, and cannot be metered readily using standard OFGEM approved metering.
If after reading all this, you are still uncertain what size or type of turbine you need, please call us and we'll help you decide!
Return to the Wind Turbines Page
This page was last updated on 15/11/2007
